Old 07-11-2021, 09:27 PM
MAStuart MAStuart is offline
Originally Posted by DonB View Post
Does it matter if dif is higher than trans? My engine drop is 3° down and my dif is 3° up but dif is higher than output shaft of trans.
Wont matter unless the pinion climbs ring gear. In that case it will get more up pinion angle. If it gets too severe it will brake the rear u joint. Under acceleration you will start to feel it binding. I dont know what type of rear setup have but if there is rubber mounts or bushings or parallel leaf springs you would be better off with the pinion set at 0 degrees.
