Old 07-12-2021, 05:52 PM
Steve Gallegos Steve Gallegos is offline
My BD came with a metal tank. Very thin and developed pin hole leaks, I think from rocks hitting it. I tried to repair it for about 3yrs. Last year had one made, same dimensions but heaver steel. Added another bolt and nut to support it. So far so good. When you drop your tank, you might want to cut an access hole in your trunk to get to the fuel sender and return if you add EFI, you can even do with the fuel tank in, it's easier to measure the opening for the trunk.
