Old 07-17-2021, 01:55 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
You mean the floats that are inside the bowls, I presume. Man, that's a pretty basic carb adjustment. If that's all it was, then your first shop did a super shi**y job tuning the carb.
Yes, if this is all that was wrong, then how anybody can fit a carb and not verify the float levels are correct, should stop working on carburetors.
Any carb out of the box will be wrong from the float bouncing around in the box.
Gary
