Old 07-18-2021, 12:01 PM
ERA174's Avatar
ERA174 ERA174 is offline
Cobra Make, Engine: ERA 427, 482ci sideoiler
Testing clutch disengagement: With the vehicle stopped, transmission in neutral and the engine running depress the clutch, wait a few seconds, then put the transmission in reverse. Reverse doesn't have a syncro like the forward gears. If you feel the gears grinding/hitting before they engage then your clutch is not fully disengaging. Also, check the bushings where the shifter rods connect to the shift arms, a worn/missing bushing could cause interlock issues, even if the shifter is aligned properly. Hope it's an easy fix.
