Thread: Vapor Lock
Old 07-19-2021, 02:54 PM
SwiftDB4 SwiftDB4 is offline
Cobra Make, Engine: SPF GT40
Originally Posted by ERA174 View Post
Replacement fuel pump topic has recently been discussed in this thread, worth a look. The Holley 12-125 or 12-150 may work for you.
Holley Fuel Pump 12-125
Holley Fuel Pump Chart link, https://documents.holley.com/holleyf...ems_chart1.pdf
I would avoid the Holley gerotor fuel pumps. Went thru two of them in short order due to o ring seal failure on the shaft. Can only be repaired by sending them back to Holley.
Have had much better luck with Carter P4600 fuel pump.
