Thread: Vapor Lock
Old 07-19-2021, 02:57 PM
Tommy's Avatar
Tommy Tommy is offline
Originally Posted by SwiftDB4 View Post
I would avoid the Holley gerotor fuel pumps. Went thru two of them in short order due to o ring seal failure on the shaft. Can only be repaired by sending them back to Holley.
Have had much better luck with Carter P4600 fuel pump.
It would be wise to check out a wide range of reviews. My experience was just the opposite of the above. I just replaced a Carter P4600HP after 20 hours of use due to a failed internal pressure regulator. A small number of anecdotes don't tell you much.
Tommy
Previously owned EM Cobra
