Old 07-25-2021, 06:03 AM
patrickt patrickt is offline
Originally Posted by Lalmeida617 View Post
Ok guys few more questions.
Spider cracking on the trunk -- could be a PITA to fix. Have to see it to be sure.
The car very easily came out of second gear, maybe the shift boot? -- Most likely.
Engine is Southern Automotive any good? -- Like any of the long time engine builders around here, you'll get some that love them, some that claim they were screwed.
The turkey pans corners where the cables and fuel lines went through looked like it was done with a cutoff wheel and grinder is this normal of Southern? -- You can clean that up if it bugs you, or a new TP can be had for a couple of hundred bucks. Two piece removable ones are a bit more (and well worth it).
Turn signal was very touchy the wheel had to be in just the right spot to activate them. -- Ehhhhh, just use hand signals if someone is behind you.
Both valve covers leak oil no biggie. -- Fixable.
The 427 badges on the pass valve cover was worn off near the filler cap normal for 1800mi? -- Replaceable.
The pedals were loose, (the part you put your foot on was floppy) is this normal? -- I don't know the SPF pedals as well as I do ERA/KMS/CSX pedals, which have springs behind the pedal faces. If the SPF is similar, and the springs are missing, it will cause looseness.
Pipes needed a repaint but I think that’s kind of common maintenance on these? -- If they were powder coated then they wouldn't need paint, but again, that doesn't sound like a big deal.
The radiator tank had a small leak in the corner developing easy fix. -- Fixable.
Coolant gauge never went over 80? That was strange. -- It's probably broken. Whether it's mechanical or electrical, figure it will cost a couple of hundred bucks.
The car ran good no sign of overheating or anything. -- OK, but with a broken temperature gauge on the dash I would shoot the radiator hoses with an IR gun.
When you turn the fan switch on all the gauges surge and go right back, is this normal? -- No, but it's fixable.
Also the reverse speedo had a slight needle bounce normal? -- Not unusual, and the reverser on the speedo might have a zerk fitting on it, just like your tie rod. If so, grease it up.
Lastly it had several diff keys one for the glovebox another ignition another trunk. Normal? -- Ehhh, I wouldn't worry about that.
If the car runs well, after at least a 20 minute drive, and the engine's thermostatic fans are cycling normally, then the fact that you didn't shoot the hoses with a gun is probably not a big deal. 1800 miles on these cars isn't even broken in yet.
