All the things listed are either normal or can be fixed and/or adjusted.
Oil and water temp gauges:
Realize the unit of measurement is in celcius so the temp you stated could be normal depending the type of weather and driving you did.
Speedo: fairly normal at low speed. Lube or less cable bend radius may resolve depending on severity.
Keys: bonnett and boot key, ignition key, locking gas cap key and glove box key....there's your potential key inventory.
