Thread: Back up light
Old 08-04-2021, 11:10 AM
cycleguy55's Avatar
Originally Posted by SBSerpent View Post
Two questions:
1) I have a 2011 build (#983). Is there a wired connector coming from the Tremec transmission or shifter that is for a back up light connection? If so, where is it located?
2) Recommendations for an aftermarket back up light?
Assuming you have a TKO transmission, the back-up lamp / reverse switch is located on the left side of the case 7.23" / 183.67 mm from the transmission front mounting face. The neutral switch is on the left side as well, near the top of the case at the rear - that will be the one with the cable. If you go with an LED back-up lamp it should have such low current draw that you shouldn't need a relay - just feed it 12V on one terminal and connect the other to the positive terminal on your LED.
https://www.tremec.com/anexos/TRSM-TKO-0711-R1_3.pdf
Brian
