Old 08-08-2021, 01:31 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Are there relays in the lighting circuit?
Somebody have a wiring diagram they can send me?
I suggest you first photograph the wiring on the switch, then remove it and bench test it with on OHM Meter. First confirm the switch is working. You can then follow the wiring to the low beams and make them work. I would assume there is at least one relay, or perhaps two hidden somewhere.
Diagram for me anyone?
Blas
SPFWiringDiagrams@Comcast.net
