Old 08-11-2021, 07:16 AM
DanEC's Avatar
DanEC DanEC is offline
Not all aftermarket bell housings are the same. In general QuickTime are a bit more compact than Lakewood. Also QuickTime makes a non-SFI rated, steel bellhousing with a block saver plate that is quite a bit less bulky, especially along the bottom part where it does away with the heavy, wide flange and continuous row of large bolts - for a narrower flange with just a few small machine screws. If you going to the strip or someplace you need an SFI rated bellhousing this is the way to go with a Cobra. Good ground clearance, heavy steel bell with the weakened zone oriented down, block saver plate, usually dials in good on factory dowels.
ERA 782 Running
