Thread: Hard shifting
Old 08-27-2021, 04:53 PM
Grubby's Avatar
Grubby Grubby is offline
Cobra Make, Engine: ERA 838
I haven't tried, but I suspect, it you pull the trans and set up your dial indicator on the clutch, you will be able to check runout.
As others have suggested, I would think other items are more likely. Also, the need for low runout is because modern transmissions use tappered bearings. I think a toploader has ball bearings and wouldn't require as low of a runout number.
John
