Old 09-05-2021, 12:05 PM
SBSerpent's Avatar
SBSerpent SBSerpent is offline
Cobra Make, Engine: BDR build #983, FRM 392
Originally Posted by NROTOXIN View Post
Do you have electric radiator fans that you can manually turn on for around 5 to 10 minutes to cool your whole engine compartment down? How about a phenolic spacer under the carburetor? There are 1/4" spacers that would arguably work to isolate the carb from from the manifold. The two mentioned together might mitigate your issue.
I do have a toggle switch to turn on the electric puller fan after turning off the car. Opening the hood also probably helps with venting the hot air from underneath the hood.
The phenolic spacer is also a good idea for reducing the conductive heat transfer from the intake manifold to the carb. I will need to see how thick of a spacer I can use being that the air cleaner cover sits very close to the cowl - maybe 1/4" gap there.
