  #25 (permalink)
Old 09-08-2021, 08:17 PM
Unique427 Unique427 is offline
Originally Posted by SBSerpent View Post
I did a search and found a Sunoco station close by that sells these different grades of fuel. Do they need to be used by themselves or can you mix with conventional fuels (understanding that you dilute the capabilities of the Sunoco fuel in doing so). Do you risk any damage to rubber seals/gaskets/Orings by using these higher grade fuels?
There will be no ill effects on seals/gaskets/O-rings, etc using unleaded
non-oxygenated race gas. It is PURE gasoline made without ethanol.
Blending race gas with pump gas is no problem. You will need to do
a little math to get the desired octane rating. Example is a 50/50
blend of 91 octane unleaded non-oxy pump gas with Sunoco 260GTX
98 octane unleaded non-oxy produces a blended octane rating of 94.5.
I run the above mix during hot Summer months or car parades.
BBF, carb, mechanical pump, no return line or phenolic spacer.
Fuel line is 1/2" SS braided Aeroquip with air-gap between block.
+90F car parades with lots of stop-n-go but no vapor lock.
Hot restarts have not been an issue during parades as well.
May not work for everyone but this seems to work on my car.
Really hope this helps you out even a little.
Read Sunoco's info about mixing here:
https://www.sunocoracefuels.com/tech...ulating-octane
Bonus: burning race gas your exhaust will smell a bit sweeter!!
