Old 09-12-2021, 11:07 AM
eschaider's Avatar
Originally Posted by CLV8 View Post
Ed, there are so much wear that no need to measure them. When you take a valve in hand you can move it very easily on the guide (0.03" to 0.04" wear).
If the valves can be noticeably moved side to side you probably have worn guides and they would be the source of the oil entering the intake ports.
If we accept the worn guides answer to the What question, the questions that remain to be answered are the Why did they fail and the How to fix questions so as to avoid a repeat performance.
BTW .003 to .004" stem to guide clearance while not desireable, on a street driven car it is also not that bad. The amount of oil you are showing in the ports belies .003 or .004" clearance.
Ed
