Old 09-15-2021, 01:05 PM
undy's Avatar
undy undy is offline
Originally Posted by CLV8 View Post
Today I brought my heads to a racing engine specialist and discussed about the valve wears.
For him my problem can be:
- Bad/wrong valve guides machining when heads have been built
OR
- too much camshaft lift incompatible with heads can accept. Edelbrock RPM Performer heads allow .600" maximum valve lift.
FOR BRENT: Do you have my camshaft specs when you built the engine ? I don't have any specs or camshaft reference.
Thanks, OliveR
Let's hope you didn't understand exactly what the "racing engine specialist" said. It's either that or he didn't tell you the whole/correct story. Your "heads" don't dictate maximum lift. The installed valve springs accomplish that. Edelbrock was referring to the max lift on their installed valve springs. The valve springs are matched to the cam. My 482" aluminum Pond side-oiler has the FE Performer RPM heads (CNC'd) and I'm running a .650" lift cam. 20K miles in 12 years and zero oil consumption or valve/chamber coking. The guides are as new.
Too many toys?? never!
