Old 09-22-2021, 07:49 PM
markantioch markantioch is offline
Cobra Make, Engine: Classic Roadsters, Ford coyote Gen1
Originally Posted by sunman View Post
The roll bar in Marks photo looks like a cosmetic bar bolted in.
Real roll bars drop down to a 3”x3” angle, that you have to add, underneath the tray further back. Your inside bar sleeves are welded to this angle.
There is area to add plate outside of frame rails for the outside or single hoop roll bar legs.
Attach harness to roll bar because:
Shoulder belts should be attached level to shoulders and not be redirected by seats
Lower bolt location is unsafe and in an accident can cause spine compression
Party On
True dat, my shoulder harness is worthless how it's attached. I will move them to the roll bar location soon. But I assure you 100% that the roll ball is attached to the 3" frame right behind the seat, as is that bolt for the terrible shoulder harness location. If you look at the pic I posted, you should see the 4 holes where the retaining nut will be welded in. Any other questions on cosmetics? lol
Every chance I get, I'm fixing, or undoing the hacks the builder (Celina Custom Auto) built into my Cobra. It's time consuming, and expensive.
https://scontent-hou1-1.xx.fbcdn.net...c8&oe=616FBD43
Mark
