Old 09-23-2021, 04:01 AM
1795's Avatar
1795 1795 is offline
Originally Posted by 767Jockey View Post
Regarding pressure, I see:
Jon runs.............26 front, 24 rear.
HTM101 runs .....22 front, 20 rear.
Those are lower pressures than I would have guessed.
Jeff, what did you run?
A lot of it depends on how fast you are driving and the type of driving that you do. With my Hoosier TD-R's (which are a biased ply tire and similar to the billboards) I run a lower pressure, by 1 psi in the fronts 19 front, 20 rear, as I am doing a lot of hard cornering at speed and the fronts get hotter than the rears. The Hoosiers like to be at 26-27 hot, so I imagine that the Billboards are pretty similar. So, depending on how hard you drive them and ambient temperatures the air pressure that you run will differ.
My 2 cents for what it's worth.
