Thread: Msd
Old 09-26-2021, 02:30 PM
spdbrake spdbrake is offline
Originally Posted by hauss View Post
Low speed works fine, high speed car starts overheat. Found hanging distributor also, suspect water pump maybe cavitation, turning to fast ? Will look into larger diameter pulley. Have to see what I have. Not sure exactly, how to tackle this problem.
You will need a smaller water pump pulley or a large crank pulley to increase the flow.
I have not come across any larger OD Gilmer crank pulleys though.
May be dumb question, but are you sure your puller fan pulls air into the engine compartment? If the polarity is reversed it can be a pusher and work fine at low speeds and then become an effective wall at higher speeds.
