Old 06-21-2002, 05:46 AM
kountzecobra's Avatar
kountzecobra kountzecobra is offline
The only way to check a power valve is to remove it and vacuum check it. I use a small hand vacuum pump. If yours is a newer Holley, it should have a check valve ball in the vacuum passage to prevent power valve blowout. I don't believe this would prevent your car from starting.
