Old 09-27-2021, 02:57 AM
blykins blykins is offline
It’s because on the “full lift” picture he has “input” way more lift than what he has. He is trying to go to whatever mark that is on the valve and that’s not accurate. When the valve lock groove is almost touching the valve seal, that should be an indicator that somethings not right with the experiment. If you try to open the valve an inch, you’re gonna see something like that.
There is nothing wrong at all with that first picture. T&D rockers are some of the easiest to set up and I’m probably the most anal about setting up valvetrain geometry.
In addition, pushrod length has nothing to do at all with geometry on a shaft mounted rocker.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
