Old 10-04-2021, 03:18 PM
patrickt patrickt is offline
Originally Posted by Argess View Post
Also, I have heard that the zinc is important until the engine is broken in and then zincless oil is OK. I tend to believe it, but have no real evidence, just internet opinions.
If you have a SFT cam that has been nicely broken in, has gentle ramps, reasonable lift and springs that aren't too heavy then you might be right. The only way you would know for sure is to swap out your healthy ZDDP oil for the newer zincless oil and then waited to see if you ate a lobe or not. Remember, the reason ZDDP was removed from oil is that it damages the catalytic converter. If you don't have a CC on your car there is no reason to avoid ZDDP, which is an absolutely wonderful anti-wear agent.
