I will have to reach out to Alistair being that his shop is only 90 minutes from me.
On a slightly different topic, can someone please provide step by step instructions as to how to replace the two bearings on the internal steering column? I have play up and down and side to side on the steering wheel. I did check the U-clamp that is behind the dash that holds the outer column and it is tight.
Also, what is the replacement p/n for the bearing?
