Old 10-07-2021, 09:08 AM
spdbrake spdbrake is offline
Its the 1st part number listed in the 1st thread I linked. You'll need two bearings.
Remove the bottom bolt on the lower universal and pull the universal off the rack pinion spline.
Remove the two cross bolts that hold the BDR universal assy in the hollow smaller center column.
Remove the the universal assy from the hollow center column tube.
Loosen the two allen set screws that are in the large OD billet spacer. (the lower bearing is right behind it).
Slide the spacer and bearing out.
You can now pull the steering wheel and center tube out and access the upper bearing. (Outer support tube is not disturbed)
