  #40 (permalink)
Old 10-13-2021, 09:21 PM
justcobra justcobra is offline
Cobra Make, Engine: Replica Motor Company
In a conventional car the master cylinders sit high on the firewall and brake bleeding is not a problem and it can be done with one person using a brake bleeding tool.
Tiltons/Wilwood or others underfloor pedal system it is the reverse, The master cylinder bottles are mounted at floor level making the process is difficult.Sure- follow Tiltons Direction and the trick is that the bottles should be mounted high enough or raise the vehicle so as the M/C are higher than your calipers to facilitate bleeding.
