Old 10-16-2021, 09:37 AM
spdbrake spdbrake is offline
Looks pretty sweet.
Only two items i can see the the lower pedal-box cover is peeling indicating it has/had a brake or clutch fluid leak. Same issue for the R/rear tire sidewall discoloration. Could be old and already corrected.
Not what I'd call a deal breaker.
The 8 stack EFI is a great addition to the drivability.
Another thing that is well thought out is in the grill opening there are two small LED turn indicator lamps. Since the Driving lights block the opposite turn signal indicator at an oblique angle as viewed from someone at a 4-way intersection.
