Old 10-19-2021, 11:42 AM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Default 5 oh
Hi,
Change the front timing cover to an old style so you can run a standard rotation water pump when you get rid of p steering pump. The singe best mod is a set of aluminum heads, give you 50+ HP and lose 50 lbs on engine. I run edelbrock carbs as they do not leak like holleys.
Good Luck,
Perry
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
