Old 10-23-2021, 05:01 PM
RonKahn RonKahn is offline
Cobra Make, Engine: Classic Roadsters, 347 stroker
Smile
Yes, I have the same setup, without the horizontal shock mounts on the frame. I have not decided if I am going to put them on or not. I want to make sure I can get the widest tire under the car first. Is all you did is just mount to the existing mower mounting hole on the rear end and then drill a hole on the upper shock mount? I would like to get all the same items you have there. If you can post all the part numbers for the shocks and the mounts that would be great!
