Old 11-07-2021, 08:05 AM
Sycraft's Avatar
Sycraft Sycraft is offline
Cobra Make, Engine: ford 302
depends on your mounts, Sunman and I have different mounts and mine mount with a little more length. I went with brackets that are secured by 2 bolts to the frame and dual shear tabs for the shock mount. I do not trust the single frame mount, my current setup ( stock CRII) the top shock mount bent under a hard hit. I will have to straighten it before I mount my brackets. As far as bushings, I stayed with rubber for the shocks to try and dampen ride since I used spherical in the upper arms and poly in the lowers. Still in Vegas right now, but will start to update soon as I will be starting when I return.
