Thread: dimmer switch
Old 11-08-2021, 05:48 PM
Dirty Harry Dirty Harry is offline
Average Guy
Cobra Make, Engine: red Shell Valley, white stripes
Default dimmer switch
The floor-mounted dimmer switch in my car has bit the dust, and I'd like to replace it with a toggle switch of some sort to be mounted on the dash or nearby. This will alleviate a little congestion in the footbox, I think. I seldom drive at night, and don't use high beams much, so it's not like I'd be using the switch a lot.
The switch should be heavy duty and simply switch between two options, with no "off" position needed.
So far, I haven't run across a suitable switch to use. Does anyone have a suggestion and a source for one?
When I said I wanted to be somebody, I probably should have been more specific...
