Old 11-10-2021, 08:02 PM
CFD2DC CFD2DC is offline
Originally Posted by Roylerumble View Post
What parking brake handle and cable have others used, or recommend?
I have a t5 from a 91 mustang and the rear is an 8.8 that I'm planning on adding disc brakes from an SN95. I could go the donor route and use one from a mustang, but was thinking about a Lokar or equivalent. The more factory route would be to have a handle mounted between the pass seat and trans tunnel. Is that possible on the CRII? I was looking at these:
https://www.summitracing.com/parts/l...7011?rrec=true
Or if I want to stay with the handle mounted on the center of the tunnel, this:
https://www.summitracing.com/parts/lok-ehb-7000f
This is the cable I was planning on using:
https://www.summitracing.com/parts/lok-ec80tu
Is there a certain year of mustang or donor route that doesn't look have all the molded plastic? I haven't been out to look at the 90's mustangs I have because they're in storage but as far as I can remember, they look like their from the 80's/90's
I'd appreciate any advice, part suggestions, pictures, ideas
Kevin. I used that lokar handle and cable set. The only thing you have to do is somewhat fabricate the mount. The lokar is designed to be mounted from below. That will put it well below the tunnel cover and that won’t work. I turned the mount “tabs” over and changed it a bit to mount on top. It works great like that and hugs the tunnel so it’s not in the way. Won’t let me add pics. I’ll e mail them to you.
Jeff
