Old 11-21-2021, 06:21 PM
sunman's Avatar
sunman sunman is offline
The 1994 and up SN95 axels are 1 1/2” wider total. Up to 98 used same housing. Your axels stick out more. Check out the difference. Change them out *******AXELS ONLY*******
Put your wheels on to measure track width, it’s the wheel center
Fronts on this are 9” wide rim 3 3/4” backspace 245/50/16
Back 10” with 4 1/2” backspace 255/50/16
CR II supplied wheel size and backspace
You can go wider in back to the inside
Chaney Shores Studio
