Old 11-25-2021, 12:09 PM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
Originally Posted by Grubby View Post
Morris - what is the Sweet part number you used? Do you cut the steering column shaft and then weld the Sweet male piece to it (the part that stays in the car)? On the part that removes, is it all bolted together or is it welded?
John
John
I just ordered the splined 3/4” shaft and welded it on the steering shaft at the height I wanted it......the took the barrel and machined out the O.D. For the Sweet Quick release and the thickness so we could stick the Sweet inside the barrel with 2 cut outs to grab the Sweet rim to release it...then we just drill holes in the barrel to match the Sweet release....and the Barrel all ready had the steering wheel mounting bolt holes....
Morris
