Old 11-26-2021, 08:22 AM
RonKahn RonKahn is offline
Cobra Make, Engine: Classic Roadsters, 347 stroker
Originally Posted by Sycraft View Post
QA1-DS602
Coilover Shock, Proma Star, Twin-Tube, 18.750 in. Extended, 12.500 in. Collapsed, Eyelet/Eyelet, Each
(Mfr. #: DS602)
mine is a 8.8 as well
these fit the measurements the best, I am at 15.5 at ride height length, and 18.5 extended currently. These should give me the same range and ride in the middle of the shock stroke. went with 250lb Eibach springs, 14" to fit these coilovers. They are single adjustable, as are my fronts. Did not see a reason to go double adj as its a street car for me, will not see track time. I will be using UPR lower mount designed for the 8.8 rear end and recently sourced an upper mount from outcastautoworks. https://www.outcastautoworks.com/col...r-mounting-kit I put a pic of bracket in gallery, would not let me attach here
What version front shock/coilover spring rate are you using on the front?
