  #27 (permalink)
Old 11-28-2021, 10:51 AM
spdbrake spdbrake is offline
Originally Posted by Seanpatrick View Post
Received all the parts but when i installed the linkage it seemed to bind on the lower u joint connected to the rack. Its seems like the angle from the upper u joint needs to be higher for it to turn without binding. I checked the invoice, it seems to be the correct u joint. Any ideas Thanks Sean
Are your u-joints phased correctly? see page 7
http://www.woodwardsteering.com/PDF/...d%20Shafts.pdf
also you can loosen the steering rack mounts and tilt it slightly aft and it will pretty much center the lower steering u-joint which pretty much make the upper u-joint the only one bending.
Please post pics.
