Old 11-28-2021, 02:01 PM
spdbrake spdbrake is offline
Looks good.
Last thing I'd recommend is adding a divot (with a sanding drum or grinder) to the the ends of the Double shaft, and a drilled divot to the upper splined shaft for the set screws to lock into. Last thing you want is to pull back on the steering wheel and the shafts disengage.
