  #30 (permalink)
Old 11-29-2021, 06:22 AM
Quentin Z's Avatar
Quentin Z Quentin Z is offline
Cobra Make, Engine: Backdraft #272, 351W
Originally Posted by spdbrake View Post
Looks good.
Last thing I'd recommend is adding a divot (with a sanding drum or grinder) to the the ends of the Double shaft, and a drilled divot to the upper splined shaft for the set screws to lock into. Last thing you want is to pull back on the steering wheel and the shafts disengage.
...and a coat of paint to all (unless you picked up the SS DD shaft).
