Old 11-29-2021, 03:23 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by eschaider View Post
Blair's advice is spot on (IMO). The non synthetics will help the rings seat more quickly. The synthetics are more slippery and while the compression rings may seat well the oil rails will have a bit of a struggle. Eventually they will all seat but why go through the pain when it is not necessary. The old Dino based oils and the newer commercially available break-in oils in particular will do a very nice job for you during break-in.
The other thing not to use is any type of friction modifier. Same problem — oil ring seating and potentially a longer seating effort for the compression rings also. Once everything is seated, most any friction modifier you want to use will not only be good but also protect the engine during cold starts while the oil galleys need to get repressurized. Those few moments before the various bearing surfaces see pressurized lubrication is when the majority of engine component wear occurs.
Ed
Thanks, Ed. I appreciate all the info you've sent along the way on both this and the quick disconnect hub as well. What method do you use to get all the old oil out of the cooler and lines when you change your oil?
Doug
