Old 12-22-2021, 06:02 AM
fastpace fastpace is offline
Cobra Make, Engine: CSX2410
Originally Posted by 767Jockey View Post
I had a red light in the dash that was on all the time. It was super annoying, I disconnected it. I wonder if that was the issue. I'd rather have the resistor. They have 560 ohm resistors on Amazon. Would the 2 watt resistors be durable enough for this application? I have no idea. I'd really rather not have to look at that bright red light all the time if I don't have to. Do I need to reconnect the light AND a resistor, or will just the resistor suffice?
2 watt should be more than enough, that 160mA at 12V. You can have just a 560 ohm resistor, you don't need the light. If you had the light and you've since taken it out then that is definitely the source of your issue.
