Old 12-22-2021, 03:13 PM
stephen low's Avatar
stephen low stephen low is offline
Default Suspension geometry settings
Greg
Had my car set up by Rob Tuckett, a respected Historic Mustang racer and it behaves nicely.
I do have Jag gear set up all round on Koni shocks but I'm not sure if the different suspension bits coming into play in terms of the settings, I'm guessing not.
I don't have power steering.
Anyway, reading from the printout as follows:
Front
Camber - Left - 1 degree 25 seconds Right - 1 degree 20 seconds
Caster - Left 2 degrees 30 seconds Right 2 degrees 10 seconds
Toe - Left 0.2mm Right 0.3mm
Rear
Camber - Left - 1 degree even Right _ 1 degree even
Toe - Left 0.4mm Right 0.3mm
Steve
slowy
