Old 12-25-2021, 01:20 PM
patrickt patrickt is offline
Originally Posted by Tommy View Post
First, I've not heard of the crankcase pressure being higher on one side of the engine than the other, and it doesn't sound right to me. Second, I looked at a few old threads re "catch can" and didn't see anything about crankcase pressure. So I'd like to see a link to the discussion that does. Third, I did find a discussion that suggested that the right side valve cover would have a higher oil level (and thus more oil droplets in the vapor) in race cars driven by high level drivers on a counter-clockwise course. That is because the G forces would pull oil toward the outside during the mostly left hand turns. As the OP is not likely to fall into this category of user, I stand by my earlier opinion that it doesn't much matter which valve covers has the PCV connection and which has the breather.
What do you bet that if you hunt around you can find that exact same engine in something else from Ford, or a different year, that has the PCV over on the other side.
