Old 12-25-2021, 08:11 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Now I'm all confused - not hard to do when it comes to electrical.
1- If I take out the light from the circuit and install JUST a 560 ohm resistor in the line that runs from the alternator to the ignition switch, will it work?
2- Does it matter if that line runs to the IGN or ACC terminal on the iginition switch?? If so which terminal should I run it to?
