  #25 (permalink)
Old 12-28-2021, 10:41 AM
1985 CCX's Avatar
1985 CCX 1985 CCX is offline
Ok, I'll try
I do not dump the clutch as I am not a drag racer. With alloy flywheel it hesitates a touch once you begin to move unless on the gas hard. Inertia is not there however once you start to move it rips like a rocket. RPM's fast!
Its like a two stroke dirt bike, pulls like a freight train.
Example the ACMKIV car, steel flywheel, almost can catch momentum if you let the clutch out slow with no gas.
The MKII will stall unless you give it some fuel.
Once moving the MKII is like a rocket where the MKIV is like a regular car and also smoother.
Granted the MKII is set up different, best I can do to describe it.
