Old 01-03-2022, 06:12 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
The mounting edge/plate for quick jack is pretty much perpendicular to the frame of the vehicle. The mounting plate for the Over-Riders is angled and requires cutting the tubes/mounting studs to get them to mount properly.
Be prepared, depending on the source of the Over-Riders they may line up well but more than likely, it will be a very tedious job to get them to line up.
A tip for you. If you are only mounting the over-riders, it's not too bad a job, and being close with the angle will work. The angle of the plate should match the angle of the edges of the nose opening, top to bottom.
If you are going to mount the chrome nose hoop, be prepared for a real hassle. There are a bunch of angles that have to line up to get them to mount properly. It takes a lot of ADULT words and beverages to get it done
www.65shlb.com
www.prdcrrct.com
