  #34 (permalink)
Old 01-04-2022, 08:38 AM
Tom Wells's Avatar
Tom Wells Tom Wells is offline
I had carbs on both cars initially. Now they each have multi port EFI from Holley - the HP model. Considering they were tuned by a rank amateur (me!) they run fine.
I would have kept the carbs except for one thing: the substance we laughingly call gasoline.
When the Cobras were new in the sixties, gasoline was quite different from what we have now. The current boiling point of alcohol-laced gasoline is hardly over 100 degrees F. After a nice run in either car I could watch the Holley carb bowl vents emulate Old Faithful as the lower temp fractions boiled away, flooding the engine.
EFI has a 44 psi fuel pressure that keeps the boiling from happening.
So good luck with the carbs...
Tom
PS: the no-alcohol gasoline may help with a carb - never tried it, as it wasn't available when I had to switch.
