Thread: Engine upgrade
Old 01-07-2022, 11:45 AM
767Jockey's Avatar
767Jockey 767Jockey is offline
What Mike wrote above is good info. One note however, is that the part numbers given by Contemporary in the manual are for the actual steel and rubber motor mounts that bolt to the engine. Note the line above those part numbers where it says that at the time of ordering you must tell them what engine you'll be using. That's because the actual mounts welded to the frame are different for each engine family that Contemporary made provisions for. In your case the frame was built to accomodate the Cleveland and subsequently no matter what motor mount you use on your new FE the frame mount won't mate up to it. I hope that clears up any possible confusion.
