motor mounts for FE
I had issues getting my FE’s headers to line up with the cutouts. I found and can share it a picture of all the different FE mounts ford used. The mounts move the engine forward or backward so your header can like up. My suggestion is to get the motor in the car with the body on add the headers and see which mounts might work for you. I can send you the part number of the mounts I used. I made no alterations to the frame. Send me your email and I will froward you the info
Jon
The Impossible Only Takes A Little Longer
