Thread: Rear end issues
Old 01-13-2022, 02:19 PM
169mph 169mph is offline
Originally Posted by hauss View Post
Have you removed the dust cover on the flange side of the axle and checked the flange bolts? The grease you are seeing is coming from the cv joint they are packed full of grease I would bet that the bolts are broken or something is amiss with your cv joint.
No. I'm idiot. I just figured out what everyone was referring to when asking if the inner bolts were loose. I thought y'all were talking about the flange bolts.
I assume I need to pull the axle out to remove the dust cover so I can inspect the inner bolts. It cant be done in place?
Also, there are no noises coming from the rear end when driving. It's tough to hear anything other than the exhaust. There is very little movement of the axles/cv joints up and down or in and out. Very minimum. Less than 1/16"
Thanks, Mike
