Thread: Rear end issues
Old 01-16-2022, 04:37 PM
169mph 169mph is offline
Originally Posted by Gaz64 View Post
Seems your pics are not displaying in the correct orientation for others to view.
Hence the confusion for which way is up.
To me, the inner CVs are rubbing, after the diff housing has moved UP not necessarily forward. So there is either some broken mounts, or the rear chassis frame is broken.
10mm gaps are more normal.
Gary
Yeah I definitely need to label or rotate the pics. I sure hope you are wrong. Broken chassis sounds like a cut your losses type scenario. I live in the Houston area. Does anyone recommend a shop to send my car to? wow! Thanks again for the feed back.
