Thread: Rear end issues
Old 01-16-2022, 06:20 PM
FredG's Avatar
FredG FredG is offline
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Default Following here also....Normal clearance??
I too have been following this. Interesting problem. What would the normal clearance be for the CV joint and the carrier? I would imagine it's pretty close.
Fred
Originally Posted by spdbrake View Post
Back to an earlier response to the two aft diff bolts.
You had replied: "Thanks for the picture. Those bolts are there. "
But did you check if they are tight?
They're 21MM if I remember correctly and most folk's home tool sets end at 19MM.
I ask again because your diff is sliding aft in the mount and the Bolt appears to have a gap where you can see exposed threads.
